Zum Hauptinhalt wechseln
Parrot Skycontroller 2 Buttons Replacement
Was du brauchst
  1. Parrot Skycontroller 2 Buttons Replacement, Battery: Schritt 1, Bild 1 von 3 Parrot Skycontroller 2 Buttons Replacement, Battery: Schritt 1, Bild 2 von 3 Parrot Skycontroller 2 Buttons Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip your controller face down.
  2. Parrot Skycontroller 2 Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Buttons Replacement: Schritt 3, Bild 1 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 3, Bild 2 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Buttons Replacement: Schritt 4, Bild 1 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 4, Bild 2 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 4, Bild 3 von 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 Buttons Replacement: Schritt 5, Bild 1 von 2 Parrot Skycontroller 2 Buttons Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
  6. Parrot Skycontroller 2 Buttons Replacement, Buttons: Schritt 6, Bild 1 von 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Buttons Replacement: Schritt 7, Bild 1 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 7, Bild 2 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 7, Bild 3 von 3
    • Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Buttons Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Buttons Replacement: Schritt 9, Bild 1 von 1
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Buttons Replacement: Schritt 10, Bild 1 von 2 Parrot Skycontroller 2 Buttons Replacement: Schritt 10, Bild 2 von 2
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
  11. Parrot Skycontroller 2 Buttons Replacement: Schritt 11, Bild 1 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 11, Bild 2 von 3 Parrot Skycontroller 2 Buttons Replacement: Schritt 11, Bild 3 von 3
    • Use some force pull up and out on the rubber backing for the buttons.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 315
