Zum Hauptinhalt wechseln
Patching a 125 2 stroke fuel tank
Was du brauchst
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: Schritt 1, Bild 1 von 1
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
  2. Patching a 125 2 stroke fuel tank: Schritt 2, Bild 1 von 1
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
  3. Patching a 125 2 stroke fuel tank: Schritt 3, Bild 1 von 1
    • Make sure that the ointment is spread thickly over the hole.
  4. Patching a 125 2 stroke fuel tank: Schritt 4, Bild 1 von 1
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
  5. Patching a 125 2 stroke fuel tank: Schritt 6, Bild 1 von 1
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
  6. Patching a 125 2 stroke fuel tank: Schritt 7, Bild 1 von 1
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    • Once patch is dry put fuel in the tank.
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    • If there are leaks scrape off patch and repeat process.
  7. Patching a 125 2 stroke fuel tank: Schritt 11, Bild 1 von 1
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew
1.339 Reputation
2 Anleitungen geschrieben
Vegas Room H9 Mitglied von Vegas Room H9
Community
13 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 44
Insgesamt: 920
