Zum Hauptinhalt wechseln
Einleitung
Is your Pebble Steel not vibrating properly? Replacing the vibration motor may solve this problem.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 1 von 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 2 von 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: Schritt 1, Bild 3 von 3
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Vibration Motor Replacement: Schritt 2, Bild 1 von 2 Pebble Steel Vibration Motor Replacement: Schritt 2, Bild 2 von 2
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: Schritt 3, Bild 1 von 1
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
  4. Pebble Steel Vibration Motor Replacement: Schritt 4, Bild 1 von 1
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
USF Tampa, Team 1-7, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Antwort
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 15
Insgesamt: 2,818
