Einleitung
Removal of battery for replacement.
Was du brauchst
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
Disconnect the screen from the circuit board.
Locate the three screws on the circuit board.
Remove using the J000 Philips head screwdriver.
Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
Move apart the connector to expose the fourth screw.
Remove the final screw from the circuit board with a J000 Philips head screwdriver.
Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
Remove the circuit board from the case.
After removing the circuit board, the battery is located in the middle of the case.
Locate the battery connector on the left side of the case.
Carefully disconnect the wire using a metal spudger.
After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
32 weitere Personen haben diese Anleitung absolviert.
11 Kommentare
Where did you purchase the replacement battery?
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
