Zum Hauptinhalt wechseln
Pebble Time Circuit Board Replacement
Was du brauchst
  1. Pebble Time Circuit Board Replacement, Screen Cover: Schritt 1, Bild 1 von 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: Schritt 2, Bild 1 von 2 Pebble Time Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: Schritt 5, Bild 1 von 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: Schritt 6, Bild 1 von 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: Schritt 7, Bild 1 von 3 Pebble Time Circuit Board Replacement: Schritt 7, Bild 2 von 3 Pebble Time Circuit Board Replacement: Schritt 7, Bild 3 von 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: Schritt 8, Bild 1 von 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: Schritt 9, Bild 1 von 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: Schritt 10, Bild 1 von 3 Pebble Time Circuit Board Replacement: Schritt 10, Bild 2 von 3 Pebble Time Circuit Board Replacement: Schritt 10, Bild 3 von 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: Schritt 11, Bild 1 von 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: Schritt 12, Bild 1 von 2 Pebble Time Circuit Board Replacement: Schritt 12, Bild 2 von 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Abschluss
Nicolas Hempe
1.444 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Spring 2017 Mitglied von USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 840
