Zum Hauptinhalt wechseln
Pebble Time Round Glass Screen Protector Replacement
Was du brauchst
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: Schritt 1, Bild 1 von 1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: Schritt 2, Bild 1 von 1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
Abschluss
Kyle
85 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 306
