Einleitung
Replacement guide for the screen of the Pebble Time.
Was du brauchst
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
Disconnect the screen from the circuit board.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
