Zum Hauptinhalt wechseln
Pebble Time Screen Replacement
Was du brauchst
  1. Pebble Time Screen Replacement, Screen Cover: Schritt 1, Bild 1 von 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: Schritt 2, Bild 1 von 2 Pebble Time Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: Schritt 3, Bild 1 von 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: Schritt 4, Bild 1 von 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: Schritt 6, Bild 1 von 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: Schritt 7, Bild 1 von 3 Pebble Time Screen Replacement: Schritt 7, Bild 2 von 3 Pebble Time Screen Replacement: Schritt 7, Bild 3 von 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Saud Al-Malki
110 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-3, Sullivan Spring 2017 Mitglied von USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
4 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
Where can I buy the display replacement?
ulises - Antwort
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - Antwort
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 3,174
