Einleitung
The watch is opened and i think it won't be waterrestant any more after this.
Was du brauchst
With opening picks we start to open the watch by lifting up the display bottom from left (about seven o'clock) in counterclockwise direction. In the left side there is a flexband that has to be disconnected.
down on the left, a Flexband is carefully folded up and loosened. Below it, another screw is visible.
Remove this screw.
Then the board can be removed carefully.
If you look closely at the keys, you can see that the defective key no longer carries rubber dabs.
With a needle, the smallest drops of superglue are dripped into place of the missing rubber.
Now put everything together in reverse order. Remove the sealant before applying the display and stick it around with a new Tesa 61395 Tape 1mm.
Then insert the display and press down.
Repeat the steps in reverse order to reassemble your device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
2 Kommentare
thanks , I managed to fix my pebble time steel with this guide. it may not be waterproof but at least my buttons no longer stick…
I think the reason it failed was because some water already got inside… could get my pebble starting anymore
Works great! Thanks for the guide :D
I would've liked to add an additional step, but it doesn't appear that I can - one other thing that I've found can cause buttons to stick is in the inside of the casing, on each button there's a little circlip that sits in a detent on the pokey bit - if this comes out of its detent, then the button can become quite hard to press and hard to work with. Unfortunately I can't post pictures here, but there's a picture in this Imgur thread of what I'm talking about: https://imgur.com/gallery/V4SUvbz
