Zum Hauptinhalt wechseln
Penguin FZ-8 28” Tower Fan Blade Replacement
Was du brauchst
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: Schritt 1, Bild 1 von 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 2, Bild 1 von 3 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 2, Bild 2 von 3 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 2, Bild 3 von 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 3, Bild 1 von 2 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 3, Bild 2 von 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 4, Bild 1 von 2 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 5, Bild 1 von 2 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 5, Bild 2 von 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 6, Bild 1 von 2 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 6, Bild 2 von 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 8, Bild 1 von 2 Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: Schritt 9, Bild 1 von 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Abschluss
Ethan
169 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S2-G4, Riel Spring 2021 Mitglied von UMass Dartmouth, Team S2-G4, Riel Spring 2021
UMASSD-RIEL-S21S2G4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 1,181
