Einleitung
Following the steps in this guide will demonstrate how to fix a broken or damaged impeller in a Penn-Plax Cascade 20 Power Filter. A broken or damaged impeller may cause the filter to malfunction and water to flow inefficiently. The filter system and the impeller are relatively small, so being aware of where the parts go is important.
The filter system should be unplugged and free of water and dirt before starting. There are no special skills required.
This guide will help you replace your impeller in no time.
Was du brauchst
Remove all detachable pieces from the filter. This includes the lid, pipe, and filter media.
Take your filter and place it upside down.
Place your hand on the motor. Grab it firmly and turn it clockwise for a quarter turn. When the turn is complete, it should look like the second picture.
Pull the motor up and out from the filter chassis.
Take your index finger and thumb and firmly grip one of the impeller blades.
Pull the impeller up and out of the motor shaft.
To install a new impeller, grab it by the fins and place it back into the motor shaft hole.
Push the new impeller in and make sure it is connected to the magnetic seal. This can be checked by flipping the motor upside down and seeing if the impeller falls out.
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
