Zum Hauptinhalt wechseln
Penny Board Trucks Replacement
Was du brauchst
  1. Penny Board Trucks Replacement, Trucks: Schritt 1, Bild 1 von 2 Penny Board Trucks Replacement, Trucks: Schritt 1, Bild 2 von 2
    • Use a skate tool to loosen the bolt in the wheel with an appropriately sized socket.
    • A skate tool will come with all the tools necessary to do this replacement from start to finish.
  2. Penny Board Trucks Replacement: Schritt 2, Bild 1 von 2 Penny Board Trucks Replacement: Schritt 2, Bild 2 von 2
    • Remove the wheel by lifting it from the truck.
    • Repeat this step for the other wheel.
  3. Penny Board Trucks Replacement: Schritt 3, Bild 1 von 2 Penny Board Trucks Replacement: Schritt 3, Bild 2 von 2
    • After completing the removal of both wheels, your board will look like this.
    • Place the skate tool over the bolt on the truck.
    • Maintain a good grip on the tool and use the Phillips screwdriver to loosen the nuts.
    • Repeat this step for all four screws.
  4. Penny Board Trucks Replacement: Schritt 4, Bild 1 von 2 Penny Board Trucks Replacement: Schritt 4, Bild 2 von 2
    • Lift the truck to remove it.
  5. Penny Board Trucks Replacement: Schritt 5, Bild 1 von 2 Penny Board Trucks Replacement: Schritt 5, Bild 2 von 2
    • Remove the screws from the board by pulling them out with your hands.
    • Use the Phillips screwdriver to loosen them more, if necessary.
Abschluss
Eduardo Ron
171 Reputation
1 Anleitung geschrieben
Texas Tech, Team S3-G9, Cowan Spring 2021 Mitglied von Texas Tech, Team S3-G9, Cowan Spring 2021
TTU-COWAN-S21S3G9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 610
