Zum Hauptinhalt wechseln
Einleitung
This guide will teach you how to properly remove the cover of the camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the following screws: Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Remove the two indicated screws on the bottom of the camera:
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Carefully pull the back of casing away from the front. Carefully pull the back of casing away from the front.
    • Carefully pull the back of casing away from the front.
  4. After removing the back cover, several things must be removed. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nicole Wong
329 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-29, Regan Winter 2011 Mitglied von Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 3,053
