Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the buttons on the back of the camera that control the various menu options.
  1. Remove all four 1 mm JIS #00 screws from the back of the camera. Remove all four 1 mm JIS #00 screws from the back of the camera.
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Use your finger to peel the grip off the top of the camera.
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Use the tweezers to remove the two buttons from the top of the camera.
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Remove the three 1 mm JIS #000 screws from the top. Remove the 1 mm JIS #000 screw from the bottom. Remove the 1 mm JIS #000 screw from the bottom.
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Carefully separate the back and the front of the camera.
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Remove the eight JS#000 screws using a screwdriver and lift panel up. This screw does not need to be removed.
    • Remove the eight JS#000 screws using a screwdriver and lift panel up.
    • This screw does not need to be removed.
  8. Once panel is removed the button 'sheet' can be removed.
    • Once panel is removed the button 'sheet' can be removed.
Abschluss
Matthew Bessette
658 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 6-7, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G7
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 186
