Zum Hauptinhalt wechseln
Pentax Optio WG-3 GPS Flash Replacement
Was du brauchst
  1. Pentax Optio WG-3 GPS Flash Replacement, Flash: Schritt 1, Bild 1 von 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Flash Replacement: Schritt 2, Bild 1 von 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Flash Replacement: Schritt 3, Bild 1 von 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Flash Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Flash Replacement: Schritt 5, Bild 1 von 1
    • Upon removing the flash, there is a 2 mm screw that needs to be removed.
  6. Pentax Optio WG-3 GPS Flash Replacement: Schritt 6, Bild 1 von 1
    • Remove the ribbon cable that attaches the flash from the circuitry.
  7. Pentax Optio WG-3 GPS Flash Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 2 mm Phillips #000 screws from the left side of the circuitry.
    • These screws attach the circuit board to the shell of the camera.
    • Remove the circuitry from the front side of the camera
  8. Pentax Optio WG-3 GPS Flash Replacement: Schritt 8, Bild 1 von 1
    • Find and remove the camera battery.
  9. Pentax Optio WG-3 GPS Flash Replacement: Schritt 9, Bild 1 von 1
    • Remove the final two 2 mm Phillips #000 screws from the front side of the circuitry.
  10. Pentax Optio WG-3 GPS Flash Replacement: Schritt 10, Bild 1 von 1
    • Pull the black front panel away from the circuitry.
    • The black panel is attached to the flash and is now ready to be removed and replaced.
    • The sensor is enclosed in the white case.
Abschluss
Cassandra Stec
181 Reputation
1 Anleitung geschrieben
IUPUI, Team 3-1, Harley Spring 2022 Mitglied von IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 267
