Zum Hauptinhalt wechseln
Pentax Optio WG-3 GPS Lens Assembly Replacement
Was du brauchst
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: Schritt 1, Bild 1 von 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 2, Bild 1 von 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 3, Bild 1 von 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 5, Bild 1 von 1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 6, Bild 1 von 1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: Schritt 7, Bild 1 von 1
    • Gently slide the lens piece to the right, remove the tape and take it out.
Abschluss
Garrett Rose
373 Reputation
2 Anleitungen geschrieben
IUPUI, Team 3-1, Harley Spring 2022 Mitglied von IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 280
