Was du brauchst
Using a Philips head screwdriver, remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
Remove the 6, 2 mm screws from each corner of the metal button pad cover.
Using tweezers remove the metal cover.
Disconnect the flex cables and replace the menu pad button or button component.
Fast fertig!
Abschluss
