Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
Remove the 8, 2 mm screws from each corner of the metal button pad cover.
Using tweezers remove the metal cover.
Now using tweezers, remove the menu button from its place.
After removing the button you can replace the entire component.
Fast fertig!
Abschluss
