Zum Hauptinhalt wechseln
Petmate 29027 Fountain Lid and Pump Replacement
Was du brauchst
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: Schritt 1, Bild 1 von 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: Schritt 1, Bild 2 von 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: Schritt 1, Bild 3 von 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: Schritt 2, Bild 1 von 3 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 2, Bild 2 von 3 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 2, Bild 3 von 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: Schritt 3, Bild 1 von 2 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 3, Bild 2 von 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: Schritt 4, Bild 1 von 3 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 4, Bild 2 von 3 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 4, Bild 3 von 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: Schritt 5, Bild 1 von 2 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 5, Bild 2 von 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: Schritt 6, Bild 1 von 2 Petmate 29027 Fountain Lid and Pump Replacement: Schritt 6, Bild 2 von 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Ziellinie
Shidie Ren
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G22, O'Regan Summer 2020 Mitglied von York University, Team S1-G22, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G22
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 508
