Zum Hauptinhalt wechseln
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Was du brauchst
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: Schritt 1, Bild 1 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: Schritt 1, Bild 2 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: Schritt 1, Bild 3 von 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 2, Bild 1 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 2, Bild 2 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 2, Bild 3 von 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 3, Bild 1 von 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 4, Bild 1 von 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 5, Bild 1 von 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 5, Bild 2 von 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 6, Bild 1 von 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 6, Bild 2 von 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 7, Bild 1 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 7, Bild 2 von 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: Schritt 7, Bild 3 von 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Abschluss
Ashley Kim
187 Reputation
1 Anleitung geschrieben
Cal Poly, Team S13-G7, White Fall 2018 Mitglied von Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 287
