Einleitung
Use this guide to replace the battery for your SmartFeeder to get your device up and running again. This guide is also a prerequisite to access and replace the motherboard and charging assembly.
Was du brauchst
Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
Remove the metal tray by using both hands and pulling out the bowl towards you.
Turn the bowl tray side down by using both hands.
Remove seven 11 mm screws by using the Phillips #1 screwdriver.
Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
Trace the wires with your hands from the battery to the motherboard.
Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
Eine weitere Person hat diese Anleitung absolviert.
