Zum Hauptinhalt wechseln
Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement
Was du brauchst
  1. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: Schritt 1, Bild 1 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: Schritt 1, Bild 2 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement, Food Dispensing Wheel: Schritt 1, Bild 3 von 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 2, Bild 1 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 2, Bild 2 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 2, Bild 3 von 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 3, Bild 1 von 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off very easily.
  4. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 4, Bild 1 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 4, Bild 2 von 3 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 4, Bild 3 von 3
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 5, Bild 1 von 2 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 5, Bild 2 von 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 6, Bild 1 von 1
    • Remove the eight 11mm screws from the central pillar using a Phillips #1 screwdriver.
  7. Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 7, Bild 1 von 2 Petnet SmartFeeder SF10E Food Dispensing Wheel Replacement: Schritt 7, Bild 2 von 2
    • Pull apart the two sides of the central pillar at the top by using both hands.
    • The two sides will not completely separate at the base.
    • With the two halves partially separated, pull out the rubber wheel with your hand.
    • A small black rectangular piece may fall out of the chute when the halves are partially separated. Reattach this by reaching into the chute and putting the pins from the piece into the holes on the side of the chute.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S13-G7, White Fall 2018 Mitglied von Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Always nice to have a link to part so we know where to buy
David - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,217
