Einleitung
Follow the procedure outlined in this guide to remove and install the circuit board for the device's bottom buttons.
Was du brauchst
Pry off the four white feet with the pointed end of the spudger
Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
Ein Kommentar
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
