Zum Hauptinhalt wechseln
Philips DC320 37 Connector Replacement
Was du brauchst
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: Schritt 1, Bild 1 von 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: Schritt 2, Bild 1 von 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: Schritt 3, Bild 1 von 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: Schritt 4, Bild 1 von 3 Philips DC320 37 Connector Replacement: Schritt 4, Bild 2 von 3 Philips DC320 37 Connector Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: Schritt 5, Bild 1 von 1
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: Schritt 7, Bild 1 von 3 Philips DC320 37 Connector Replacement: Schritt 7, Bild 2 von 3 Philips DC320 37 Connector Replacement: Schritt 7, Bild 3 von 3
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: Schritt 8, Bild 1 von 1
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
Abschluss
Greg Lane
39 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-48, Amido Spring 2013 Mitglied von Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,227
