Einleitung
Follow the procedure outlined in this guide to remove and install a speaker.
Was du brauchst
Pry off the four white feet with the pointed end of the spudger
Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
Electrical Connectors
Ribbon Connectors
Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
Slide the back panel towards top of the device and lift away from the device to detach back panel.
Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
