Zum Hauptinhalt wechseln
Philips DVP5992-F7 Audio Video Port Replacement
Was du brauchst
  1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: Schritt 1, Bild 1 von 3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: Schritt 1, Bild 2 von 3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: Schritt 1, Bild 3 von 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Audio Video Port Replacement: Schritt 2, Bild 1 von 2 Philips DVP5992-F7 Audio Video Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Audio Video Port Replacement: Schritt 3, Bild 1 von 3 Philips DVP5992-F7 Audio Video Port Replacement: Schritt 3, Bild 2 von 3 Philips DVP5992-F7 Audio Video Port Replacement: Schritt 3, Bild 3 von 3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 Audio Video Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 Audio Video Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 Audio Video Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the motherboard from the DVD player.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 318
