Einleitung
Over time, the HDMI port can become unresponsive. This guide will show you how to replace an unresponsive HDMI port on your Philips DVP5992-F7.
Was du brauchst
Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
Remove the 6.4 mm Phillips #1 screws on each side of the device.
Remove the top plate of the DVD by firmly grasping the player on both sides.
Shift the top plate towards the backside of the player.
Lift the back half of the top plate up to remove it from the player.
Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
