Zum Hauptinhalt wechseln
Philips DVP5992-F7 Power Cord Replacement
Was du brauchst
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: Schritt 1, Bild 2 von 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: Schritt 1, Bild 3 von 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: Schritt 2, Bild 1 von 2 Philips DVP5992-F7 Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: Schritt 3, Bild 1 von 3 Philips DVP5992-F7 Power Cord Replacement: Schritt 3, Bild 2 von 3 Philips DVP5992-F7 Power Cord Replacement: Schritt 3, Bild 3 von 3
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 413
