Zum Hauptinhalt wechseln
Philips DVP5992-F7 Screen Replacement
Was du brauchst
  1. Philips DVP5992-F7 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Philips DVP5992-F7 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Philips DVP5992-F7 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Screen Replacement: Schritt 2, Bild 1 von 2 Philips DVP5992-F7 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Screen Replacement: Schritt 3, Bild 1 von 3 Philips DVP5992-F7 Screen Replacement: Schritt 3, Bild 2 von 3 Philips DVP5992-F7 Screen Replacement: Schritt 3, Bild 3 von 3
    • Unplug the bundled cable connector that attaches the screen to the motherboard.
    • Remove the 3.175 mm Phillips #1 screw that connects the screen's ground wire to the shell of the DVD player.
    • Remove the three 6.35 mm Phillips #1 screws that attach the screen to the front cover of the DVD player.
  4. Philips DVP5992-F7 Screen Replacement: Schritt 4, Bild 1 von 2 Philips DVP5992-F7 Screen Replacement: Schritt 4, Bild 2 von 2
    • Slowly pull the screen backwards starting with the side farthest from the disc tray.
    • Unplug the bundled cable connector that is located close to the disc tray as you pull the screen out of the DVD player.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 244
