Zum Hauptinhalt wechseln
Philips DVP5992-F7 USB port Replacement
Was du brauchst
  1. Philips DVP5992-F7 USB port Replacement, USB port: Schritt 1, Bild 1 von 3 Philips DVP5992-F7 USB port Replacement, USB port: Schritt 1, Bild 2 von 3 Philips DVP5992-F7 USB port Replacement, USB port: Schritt 1, Bild 3 von 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 USB port Replacement: Schritt 2, Bild 1 von 2 Philips DVP5992-F7 USB port Replacement: Schritt 2, Bild 2 von 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 USB port Replacement: Schritt 3, Bild 1 von 3 Philips DVP5992-F7 USB port Replacement: Schritt 3, Bild 2 von 3 Philips DVP5992-F7 USB port Replacement: Schritt 3, Bild 3 von 3
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  4. Philips DVP5992-F7 USB port Replacement: Schritt 4, Bild 1 von 2 Philips DVP5992-F7 USB port Replacement: Schritt 4, Bild 2 von 2
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  5. Philips DVP5992-F7 USB port Replacement: Schritt 5, Bild 1 von 2 Philips DVP5992-F7 USB port Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 11
Insgesamt: 544
