Einleitung
The latch button on the Philips HD9252 air fryer allows the user to open and close the device. A faulty latch button will not allow the Philips HD9252 air fryer to open properly.
Was du brauchst
Remove the tray from the air fryer by pressing the latch button in, and pulling the handle away.
Remove the two 14.8 mm screws placed in the top of the latch using a Phillips #00 screwdriver.
Remove the two 14.8 mm screws placed on the bottom of the latch using a Phillips #00 screwdriver.
Remove the four 14.8 mm screws placed on front of the latch button using a Phillips #00 screwdriver.
Push the spring down with a nylon spudger so that it is underneath the button.
Slide the spring out of the back of the handle.
