Einleitung
Use this guide to disassemble the Philips HD9252 air fryer top, manufactured by Philips. Once this is removed, the main components of the device will be accessible, such as the timer and touch screen.
Was du brauchst
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
