Einleitung
I found the instructions partly at this pages and decided to upload the completely new here:
http://www.brunwinkel.de/2011/09/wasserk... (german)
Was du brauchst
Remove top lid
Unscrew 5x Torx (T8)
Remove red cover
Remember position of metallic bracket
Carefully remove metallic strip
llift-up the entire black electric carrying unit carefully about 1 cm
Un-click the fix of the black front cover and remove
Unscrew 3 Torx T8 at the bottom of the kettle
take 3 big flat screwdriver to 3 of the 6 holes and gently apply pressure directed to the middle to unlock the bottom cover
in parallel: with a 3rd screwdriver lift the cover by help of the occuring slit at the side
bottom cover should be revomed with gently force
Un-click the small mount to remove one half of the grip
un-fix carefully the hole half of the grip at the top of it and remove it
Don't demage the cables inside the grip
take a small screwdriver
push the black cover around the kettle over the transparent 'litre scale"
make it at both side of the kettle
pull the black cattle carefulle to the bottom of the kettle
stop, when you can see the full electric carrying unit (see also next step)
Unscrew the two Torx T8 to open the electric carrying unit to a half
unlock carefully the white rectacgular clip to release the black cover completely
Lift the electric unit
change the two marked capacitors by unsoldering the old ones
yellow 'MKP X2 0.47μF / 275V'
black '470μF / 16V' - check polarity: white stripe of the minus has to be located near the yellow capacitor!
Assemble the kettle in reverse manner and check at the end that you don't have any parts over
ENJOY YOUR WORKING KETTLE!
Now it should heat up to 100°C and make 'beep' at the end again
12 weitere Nutzer:innen haben diese Anleitung absolviert.
15 Kommentare
Dear RG! You made me hero in the eyes of my wife and saved lots of money as I will never buy ordinary kettle without a temperature choice. THANKS FOR THE FANTASTIC GIUDE!
Two notes: (1) It should be mentioned that the MKP X2 0.47μF / 275V capacitor is usually the faulty one. The posts on the German site to which you linked reported that it looses capacity until the power is no longer enough to power the 80 degree LED when it comes on. In my case, similar to the reports from the German site, the remaining capacity had been lower than 0.14μF---clearly not enough. (2) One apparently does not have to use the 26.5 x 8.5 x 17 mm version that was part of the kettle initially, I had an old X2 capacitor from a broken power supply with the same parameters but with a size of 18 x 10 x 16 mm and that worked just fine after I had extended the short connecting wires.
