Zum Hauptinhalt wechseln
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
Was du brauchst
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: Schritt 1, Bild 1 von 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: Schritt 1, Bild 2 von 2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 2, Bild 1 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 2, Bild 2 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 2, Bild 3 von 3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 3, Bild 1 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 3, Bild 2 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 3, Bild 3 von 3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 4, Bild 1 von 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 4, Bild 2 von 2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 5, Bild 1 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 5, Bild 2 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 5, Bild 3 von 3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 6, Bild 1 von 2 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 6, Bild 2 von 2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 7, Bild 1 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 7, Bild 2 von 3 Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: Schritt 7, Bild 3 von 3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
August Post
415 Reputation
3 Anleitungen geschrieben
IUPUI, Team S2-G4, Harley Fall 2017 Mitglied von IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 528
