Zum Hauptinhalt wechseln
Philips Norelco BeardTrimmer 3100 Handle Replacement
Was du brauchst
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: Schritt 1, Bild 1 von 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 2, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 2, Bild 2 von 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 3, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 3, Bild 2 von 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 4, Bild 1 von 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 4, Bild 2 von 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 4, Bild 3 von 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 5, Bild 1 von 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 5, Bild 2 von 3 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 5, Bild 3 von 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 6, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 6, Bild 2 von 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 7, Bild 1 von 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 8, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Handle Replacement: Schritt 8, Bild 2 von 2
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 15-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 5,735
