Zum Hauptinhalt wechseln
Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement
Was du brauchst
  1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Front and Back Panels: Schritt 1, Bild 1 von 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 2, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 2, Bild 2 von 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 3, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 3, Bild 2 von 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 4, Bild 1 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 4, Bild 2 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 4, Bild 3 von 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 5, Bild 1 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 5, Bild 2 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 5, Bild 3 von 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 6, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 6, Bild 2 von 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 7, Bild 1 von 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 8, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 8, Bild 2 von 2
  9. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Zoom Lock Precision Notch: Schritt 9, Bild 1 von 1
    • Locate the zoom lock precision notch in the back panel of the Beardtrimmer
  10. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 10, Bild 1 von 1
    • Set the zoom lock wheel to the lowest setting
  11. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 11, Bild 1 von 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 11, Bild 2 von 2
    • Rotate the trimmer so that the motor is facing you.
    • Now gently push down the zoom lock wheel until the white button is not showing.
  12. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 12, Bild 1 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 12, Bild 2 von 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: Schritt 12, Bild 3 von 3
    • Rotate the beardtrimmer again so that the battery is facing you.
    • With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
Abschluss
ilan
173 Reputation
1 Anleitung geschrieben
USF Tampa, Team 15-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
How to fix charging wire to the plate?
Kartik Gusain - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 4,484
