Zum Hauptinhalt wechseln
Philips Norelco OneBlade Servo Motor Replacement
Was du brauchst
  1. Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: Schritt 1, Bild 1 von 3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: Schritt 1, Bild 2 von 3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: Schritt 1, Bild 3 von 3
    • Ensure razor is off and razor blade has been removed.
  2. Philips Norelco OneBlade Servo Motor Replacement: Schritt 2, Bild 1 von 2 Philips Norelco OneBlade Servo Motor Replacement: Schritt 2, Bild 2 von 2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull casing apart.
    • Device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Servo Motor Replacement: Schritt 3, Bild 1 von 3 Philips Norelco OneBlade Servo Motor Replacement: Schritt 3, Bild 2 von 3 Philips Norelco OneBlade Servo Motor Replacement: Schritt 3, Bild 3 von 3
    • Locate wires below motor on either side of circuit board.
    • Remove solder from each joint using solder removal kit.
    • Do not attempt to remove wires by force.
  4. Philips Norelco OneBlade Servo Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove new motor from package and place in position.
    • Motor should sit above circuit board with connection prongs facing downward. Additionally, center extrusion on bottom of motor should sit in provided hole.
Abschluss
Please dispose of servo motor properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
5 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S3-G3, Harley Fall 2017 Mitglied von IUPUI, Team S3-G3, Harley Fall 2017
IUPUI-HARLEY-F17S3G3
3 Mitglieder
7 Anleitungen geschrieben
12 Kommentare
does removing the motor exposing the battery? In my unit I see some green thing underneath the motor, looks like a AA battery, can you confirm?
or is it from somewhere else? (I need to replace my battery)
Yarden Cohen - Antwort
I just dismantled my shaver, and it has a 1.2v AA size NiMH battery (suppo hsy aa1200).
João Paulo Gomes -
I’m also curious about the battery. Any one have pictures of it or know what kind of battery it has inside?
James Almeida - Antwort
João Paulo Gomes -
Thanks! This definitely helps.
James Almeida -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 85
Insgesamt: 20,235
