Zum Hauptinhalt wechseln
Philips Norelco Shaver 2100 Battery Replacement
Was du brauchst
  1. Philips Norelco Shaver 2100 Battery Replacement, Casing: Schritt 1, Bild 1 von 1
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Battery Replacement: Schritt 2, Bild 1 von 2 Philips Norelco Shaver 2100 Battery Replacement: Schritt 2, Bild 2 von 2
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Battery Replacement: Schritt 4, Bild 1 von 2 Philips Norelco Shaver 2100 Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Battery Replacement: Schritt 5, Bild 1 von 3 Philips Norelco Shaver 2100 Battery Replacement: Schritt 5, Bild 2 von 3 Philips Norelco Shaver 2100 Battery Replacement: Schritt 5, Bild 3 von 3
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Battery Replacement: Schritt 6, Bild 1 von 3 Philips Norelco Shaver 2100 Battery Replacement: Schritt 6, Bild 2 von 3 Philips Norelco Shaver 2100 Battery Replacement: Schritt 6, Bild 3 von 3
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
  7. Philips Norelco Shaver 2100 Battery Replacement, Battery: Schritt 7, Bild 1 von 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: Schritt 7, Bild 2 von 3 Philips Norelco Shaver 2100 Battery Replacement, Battery: Schritt 7, Bild 3 von 3
    • Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
  8. Philips Norelco Shaver 2100 Battery Replacement: Schritt 8, Bild 1 von 1
    • Located directly behind the circuit board, remove the battery from the device.
Abschluss
14 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G4, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G4, Thompson Fall 2017
USFT-THOMPSON-F17S1G4
3 Mitglieder
10 Anleitungen geschrieben
14 Kommentare
To remove the battery you have to actually desolder both ends from the chip.
AGUSTIN CABRA - Antwort
What are the dimensions/specs of the battery?
Haley Pearse - Antwort
regular AA rechargeable batteries will not work and can be a fire hazard.
steven - Antwort
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
Don - Antwort
I have a similar Norelco razor and replaced the battery. I can’t believe the stupid company didn’t mark the battery polarity on the board!
I think this is the first time I have ever seen a company not mark polarity.
Laz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 46
Letzte 30 Tage: 122
Insgesamt: 22,128
