Einleitung
Use this guide to replace the battery of your Philips Norelco 2100 as it may be defective.
Was du brauchst
Turn the shaver so that it is facing you.
Press the button on the shaver head to open it.
Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
14 weitere Personen haben diese Anleitung absolviert.
14 Kommentare
To remove the battery you have to actually desolder both ends from the chip.
What are the dimensions/specs of the battery?
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
