Zum Hauptinhalt wechseln
Philips Norelco Shaver Head Blade Replacement
Was du brauchst
  1. Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: Schritt 1, Bild 1 von 2 Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: Schritt 1, Bild 2 von 2
    • Begin by pressing the small button beneath the head to allow it to open.
  2. Philips Norelco Shaver Head Blade Replacement: Schritt 2, Bild 1 von 2 Philips Norelco Shaver Head Blade Replacement: Schritt 2, Bild 2 von 2
    • Grasp the sides of the head and pull straight up to detach it from the body.
  3. Philips Norelco Shaver Head Blade Replacement: Schritt 3, Bild 1 von 2 Philips Norelco Shaver Head Blade Replacement: Schritt 3, Bild 2 von 2
    • To unlock, rotate the center locking mechanism counter-clockwise.
  4. Philips Norelco Shaver Head Blade Replacement: Schritt 4, Bild 1 von 1
    • Lift the locking mechanism straight up, freeing the blades.
  5. Philips Norelco Shaver Head Blade Replacement: Schritt 5, Bild 1 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 5, Bild 2 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 5, Bild 3 von 3
    • Carefully push the blades out from behind.
    • Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
  6. Philips Norelco Shaver Head Blade Replacement: Schritt 6, Bild 1 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 6, Bild 2 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 6, Bild 3 von 3
    • Insert the new blades, making sure to face the side with the two tabs towards the center of the head.
  7. Philips Norelco Shaver Head Blade Replacement: Schritt 7, Bild 1 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 7, Bild 2 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 7, Bild 3 von 3
    • Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down.
  8. Philips Norelco Shaver Head Blade Replacement: Schritt 8, Bild 1 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 8, Bild 2 von 3 Philips Norelco Shaver Head Blade Replacement: Schritt 8, Bild 3 von 3
    • Push the head back onto the body, then close it up. Your shaver is good to go!
Ziellinie
16 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-1, Green Fall 2015 Mitglied von Cal Poly, Team 10-1, Green Fall 2015
CPSU-GREEN-F15S10G1
4 Mitglieder
7 Anleitungen geschrieben
9 Kommentare
This is a good guide thank you.
Replacing these shaver batteries would be a good guide: does anyone know how to do this?
Richard - Antwort
Very well done - better than a video because you don’t need to continually stop, restart and rewind to catch specific details.
Clif T - Antwort
The only problem I had was to insert the hinge into the body. Didn't want to push too hard as I was worried I could snap off some plastic parts. Once I had pushed the OLD unit on and off a couple of times the new one went in quite easily ( although the old unit was much more free than the new unit). Many thanks for your instructions - most useful!
Mike L. 14 March 2022
mike lowe - Antwort
How do you change the trimmer blade on back of it ? Or can you ?
Melanie Gettys - Antwort
Clear and simple tutorial. Excellent!
Greg Fullmer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 44
Letzte 30 Tage: 131
Insgesamt: 47,788
