Zum Hauptinhalt wechseln
Philips PD9000 37 Battery Replacement
Was du brauchst
  1. Philips PD9000 37 Battery Replacement, White Outer Housing: Schritt 1, Bild 1 von 3 Philips PD9000 37 Battery Replacement, White Outer Housing: Schritt 1, Bild 2 von 3 Philips PD9000 37 Battery Replacement, White Outer Housing: Schritt 1, Bild 3 von 3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Philips PD9000 37 Battery Replacement: Schritt 2, Bild 1 von 2 Philips PD9000 37 Battery Replacement: Schritt 2, Bild 2 von 2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 Battery Replacement: Schritt 3, Bild 1 von 3 Philips PD9000 37 Battery Replacement: Schritt 3, Bild 2 von 3 Philips PD9000 37 Battery Replacement: Schritt 3, Bild 3 von 3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 Battery Replacement: Schritt 4, Bild 1 von 3 Philips PD9000 37 Battery Replacement: Schritt 4, Bild 2 von 3 Philips PD9000 37 Battery Replacement: Schritt 4, Bild 3 von 3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
  5. Philips PD9000 37 Battery Replacement, Battery: Schritt 5, Bild 1 von 2 Philips PD9000 37 Battery Replacement, Battery: Schritt 5, Bild 2 von 2
    • Take the metal rounded rectangle spudger and place under battery edge.
    • Avoid breaking plastic cover.
    • press down hard on held end of spudger, you will hear the battery un-stick.
  6. Philips PD9000 37 Battery Replacement: Schritt 6, Bild 1 von 2 Philips PD9000 37 Battery Replacement: Schritt 6, Bild 2 von 2
    • Use a soldering iron to melt the metal connecting the battery wires to the mother board.
    • Quickly remove each wire after melting the metal
    • Soldering iron is HOT and will burn you.
    • Wires will get HOT and may burn you.
  7. Philips PD9000 37 Battery Replacement: Schritt 7, Bild 1 von 1
    • Properly dispose of battery as soon as possible
    • If battery is not disposed of, it may bloat and explode
    • If battery leaks, dispose of right away and wash hands.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - Antwort
Yeah. Where can I get the battery?
Bryan Allen - Antwort
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 7,316
