Zum Hauptinhalt wechseln
Philips PD9000 37 White Outer Housing Replacement
Was du brauchst
  1. Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: Schritt 1, Bild 1 von 3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: Schritt 1, Bild 2 von 3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: Schritt 1, Bild 3 von 3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Philips PD9000 37 White Outer Housing Replacement: Schritt 2, Bild 1 von 2 Philips PD9000 37 White Outer Housing Replacement: Schritt 2, Bild 2 von 2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 White Outer Housing Replacement: Schritt 3, Bild 1 von 3 Philips PD9000 37 White Outer Housing Replacement: Schritt 3, Bild 2 von 3 Philips PD9000 37 White Outer Housing Replacement: Schritt 3, Bild 3 von 3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 White Outer Housing Replacement: Schritt 4, Bild 1 von 3 Philips PD9000 37 White Outer Housing Replacement: Schritt 4, Bild 2 von 3 Philips PD9000 37 White Outer Housing Replacement: Schritt 4, Bild 3 von 3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 466
