Was du brauchst
Turn the device upside down so that the rubber feet are facing you.
Use the TR15 screw head to remove the two 46.5mm length crews located on the back.
Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
Remove the inner casing.
Remove the motor from the bottom half of the inner casing and set it to the side.
Remove the circular piece by popping it off to separate the circuit board from the top cover.
Disconnect the green and red wire connectors from their white connectors to disconnect the blower motor.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
These steps may be out of sequential order. Step 4 should probably be Step 1 and perhaps some are even missing.
