Zum Hauptinhalt wechseln
Philips Respironics V60 Fan Replacement
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
Was du brauchst
  1. Philips Respironics V60 Fan Replacement, shut down the ventilator: Schritt 1, Bild 1 von 2 Philips Respironics V60 Fan Replacement, shut down the ventilator: Schritt 1, Bild 2 von 2
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
    • Unplug the ventilator
  2. Philips Respironics V60 Fan Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the internal battery from the power harness connector.
  3. Philips Respironics V60 Fan Replacement, Top Cover: Schritt 5, Bild 1 von 1
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
    • Then remove the right side panel.
  4. Philips Respironics V60 Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the 4 screws using a screwdriver.
    • Remove the top cover.
  5. Philips Respironics V60 Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Remove the fan mount push pins that attach the fan to the back panel.
    • Pliers may be required.
  6. Philips Respironics V60 Fan Replacement: Schritt 8, Bild 1 von 1
    • Disconnect fan cable from motor controller.
  7. Philips Respironics V60 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove fan,
    • from back panel.
  8. Philips Respironics V60 Fan Replacement: Schritt 10, Bild 1 von 1
    • Remove fan filter assembly (the fan filter and housing), from outside the back panel.
    • When installing, orient the fan with the fan cable at the top inside of the fan, and orient the fan filter and housing as shown.
Abschluss
Rie Kuraoka
862 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S7-G10, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 9
Insgesamt: 427
