Zum Hauptinhalt wechseln
Philips Satinelle Gear Replacement
Was du brauchst
  1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: Schritt 1, Bild 1 von 2 Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: Schritt 1, Bild 2 von 2
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Gear Replacement: Schritt 2, Bild 1 von 3 Philips Satinelle Gear Replacement: Schritt 2, Bild 2 von 3 Philips Satinelle Gear Replacement: Schritt 2, Bild 3 von 3
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Gear Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Gear Replacement: Schritt 4, Bild 1 von 3 Philips Satinelle Gear Replacement: Schritt 4, Bild 2 von 3 Philips Satinelle Gear Replacement: Schritt 4, Bild 3 von 3
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Gear Replacement: Schritt 5, Bild 1 von 3 Philips Satinelle Gear Replacement: Schritt 5, Bild 2 von 3 Philips Satinelle Gear Replacement: Schritt 5, Bild 3 von 3
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Gear Replacement: Schritt 6, Bild 1 von 3 Philips Satinelle Gear Replacement: Schritt 6, Bild 2 von 3 Philips Satinelle Gear Replacement: Schritt 6, Bild 3 von 3
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Gear Replacement: Schritt 7, Bild 1 von 3 Philips Satinelle Gear Replacement: Schritt 7, Bild 2 von 3 Philips Satinelle Gear Replacement: Schritt 7, Bild 3 von 3
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Gear Replacement, Gear Replacement: Schritt 8, Bild 1 von 1
    • Replace the gear and re-insert the pin.
    • Ensure that pin is protruding slightly, it should not be flush.
Abschluss
IUPUI, Team S5-G5, Wilson Fall 2017 Mitglied von IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
What size pinion is used in it? Kindly help.
Wilkis James - Antwort
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - Antwort
Tienes las medidas de los engranajes
luis vega - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 1,637
