Einleitung
If you need to replace the metal rolling tracks of your Philips Satinelle, use this guide.
Was du brauchst
Unplug the device and remove the purple guard.
Remove the head by pressing the right side of the head (with the device facing away from you).
You will hear a 'click' and the head will become dislodged from the body of the device.
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
Be careful not to lose the clip. It will likely fly off when it releases.
Remove the plastic component that swings down.
Use fingernails to lift clips from stubs.
Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
Replace Metal Roller Tracks on both sides of the Tweezer Head.
