Unplug the device and remove the purple guard.
  • Unplug the device and remove the purple guard.
  • Remove the head by pressing the right side of the head (with the device facing away from you).
  • You will hear a 'click' and the head will become dislodged from the body of the device.
Kommentar hinzufügen
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip.
  • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
  • Be careful not to lose the clip. It will likely fly off when it releases.
  • The left side will swing down.
  • Remove the Tweezers.
  • Remove the plastic component that swings down.
  • Use fingernails to lift clips from stubs.
  • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  • Use a spudger to pry the gear housing unit from the base.
  • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  • Replace Tweezer Head.
  • Ensure that the gear is inserted into the gear box end of the head.
  • When closing the head, make sure that the Tweezer is seated correctly. To check this, the tweezers should spin fairly easily with the finger.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nathan Christian
Mitglied seit 11.11.2017
440 Reputation
4 Anleitungen geschrieben
IUPUI, Team S5-G5, Wilson Fall 2017 Mitglied von IUPUI, Team S5-G5, Wilson Fall 2017
IUPUI-WILSON-F17S5G5
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 120
