Einleitung
This guide is for the Philips Sonicare 2 series HX6211/46 toothbrush. It shows you how to replace the battery for this toothbrush. He is a link for a guide how to soldering which will be needed for this guide. Wie man Lötverbindungen herstellt und entlötet
  1. Remove brush on top of device.
    • Remove brush on top of device.
  2. Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
    • Remove the white battery cover as shown in the figure.
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
    • Pry the battery out of the side closest to the charging coil as shown in the photo by the red circle.
    • Do not use metal tools do to the fact that it could injury you.
    • Desolder the connection on the opposite end of the battery.
    • Well, the VOLTAGE of this battery is about 2.8 to 2.9 Volts. The size is same as that of TWO AAA Cells. Two AAA in series can easily replace the existing battery. Ni-Mh AAA cells of Energizer can do the job. Disconnect the existing battery but don’t remove the metallic connection to the circuit.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jonathan Jarvis
Mitglied seit 01.04.2016
452 Reputation
4 Anleitungen geschrieben
IUPUI, Team S6-G2, Baechle Fall 2017 Mitglied von IUPUI, Team S6-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G2
3 Mitglieder
Step 3 is incorrect. The only things keeping the internals secured in the casing are the two ‘elbows’ clearly visible in Step 3 picture 2. Simply pry these away from the depressions in the casing and the works slide out, with a little push from the top stem. The method describing the 3 red clips does no good (besides being nearly impossible to accomplish) and presents a clear risk of breaking the hair-thin wires
craig chatfield - Antwort
The method described in Step 3 to remove the internals from the casing is incorrect. Rather than prying the 3 red clips (nearly impossible anyhow) all that is required is to pry the two ‘elbows’ visible in step 3, photo 2, away from the depressions in the casing. Voila.
The two comments are correct, the earlier teardown is from a much earlier Sonicare. All the current models just need a spatula to depress the white detents while applying pressure gently from the brush end. The assembly will then easily pop right out.
jhuffaker - Antwort
How to get a new battery for this Philips Sonicare 2 Plaque control toothbrush.
Ni-Mh AAA cells of energizer can do the job. Disconnect the existing battery but don’t remove the metallic connection to the circuit.
uniquesolutions - Antwort
Thank you for the comments about removing the “innards”. I spent a couple hours yesterday trying to remove those red clips! This morning I saw the comments. It’s still a little bit of a challenge to get both elbows pried, but I found out it’s easier if you apply quite a bit of pressure to the brush end while manipulating the elbows. At first I was trying to light of pressure and the opposite elbow would always fall back into the depression while I tried to pry the other side. More pressure and the problem was resolved. Again, thanks to Craig for his observation. ifixit needs to correct the above instructions to reflect this.
lindajohnjosie - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 6
Letzte 7 Tage: 28
Letzte 30 Tage: 162
Insgesamt: 1,331
