Was du brauchst
Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
Use a Phillips screwdriver to remove the screw at the base of the metal head.
Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Great guide - but where is a good source for replacement parts?
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
