Was du brauchst
Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
Remove the internals from the casing.
Separate the upper and lower components by sliding the circuit board section and motor section away from each other.
Remove the spring.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
